Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Aug 2011
    Northern Indiana
    111
    Default Re: Weird shared nuetral w/ double breaker
    Quote Originally Posted by The Semi-Retired Electric View Post
    Breakers with handle ties are not 2 pole circuit breakers. 2 pole (and 3pole) circuit breakers are manufactured with internal common trip unless otherwise labeled. You are correct that MWBC's can use handle ties or multi-pole breakers.
    Granted a small percentage of double or three pole breakers have only one trip handle.
    But, most have a handle for each "phase" and employ internal trip and the handles handles are always tied together.
    The internal trip ensures all the "phases" will open together but the tie handle may allow a "phase" remain closed.
    I don't understand what you mean "Breakers with handle ties are not 2 pole circuit breakers".[/QUOTE]
    I meant two single pole circuit breakers, adjacent to one another, joined by handle ties may be used for MWBC's.
  2. #12
    Columbiana, Alabama
    843
    Quote Originally Posted by brrichter View Post
    I meant two single pole circuit breakers, adjacent to one another, joined by handle ties may be used for MWBC's.[/QUOTE]
    Sounds like we were both saying the same thing
    Also, it appears the OP solved his problem..life is good.
  3. #13
    Sep 2013
    Indeed, indeed.
