Results 1 to 8 of 8
    Jul 2013
    10
    Default Wood rot on garage built on dirt
    I have a detached garage that must have been built on either a dirt floor or a long ago disintegrated cement floor. The cement pad in the garage is relatively new, but extends just up to the beams, not under them.
    I'm noticing a lot of wood rot on the lower edges of the beams. Some of them have even been replaced recently (before I purchased the home), but they're looking 'fuzzy' too. I'm guessing that digging the whole way around the garage and having some flooring inserted and waterproofing done would be the best way to go, but financially, it's just not going to happen in the next year or two.
    So, I'm trying to find the most cost-effective way to mitigate further wood rot. Would painting the bottoms of the beams with a waterproofing agent do any good, if I can't get under the beams where they sit on the dirt? Any suggestions for something I could try to push under the beams, or spray down there?
    thanks in advance.
    7,592
    Default Re: Wood rot on garage built on dirt
    The best thing you can do is break the earth to wood contact, without that constant moisture and the biodegrading properties of dirt, the wood will do much better just as it is.
    7,343
    Try to upload photos for us to see the extend of the rot.
    You can use a host like photobucket.com, then post the link to your photos.
    Jul 2013
    10
    following are some pics. I know some of the wood needs to be replaced but in the meantime, any suggestions on how to at least slow the process in areas where it isn't too bad would be helpful.
    Part of the issue is that the property behind the garage slopes downward towards my garage. I initially thought this was the cause of my problems, but now realized that the wood issue is on all three sides of the garage and that's when I realized that the cement stops short of the wood structure. (I'm slowly discovering all of the lovely quirks of my old house...)
    Anyway, I'm already looking into getting some drainage done asap behind the back of the garage which would help the runoff problem. I've also got a porch roof that won't make it through another winter, so I'm already up to my eyeballs this fall. At this point, I'm looking for the quickest/cheapest fix for now to hold me over for another year....if there is one. :/
    Jul 2013
    10
    posted photos yesterday. still waiting for the moderator to approve the post.
    I guess it got flagged because of the images?
    3,120
    Pouring a slab inside the walls simply put off the inevitable, you need a properly built garage. You can;
    1- Demo the garage and slab then start from scratch
    2- Demo the garage and pour a perimeter foundation if the slab is good
    3- Support the side walls and roof while you pour a perimeter foundation
    If you live where building permits are required, my guess all they will let you do is #1, as that is the only real choice you have anyway.
    7,592
    In my neck of the woods, choice #3 is more likely the better way to go. Because it is an existing structure, you can do whatever you want to it to repair or improve it. If you tear it down, you're now into "new construction" and required to provide proper set backs, and can be limited by infill limitations. Remodel permits are much cheaper than new construction, and much less of a hassle to get approved. So my advice is to check with your local building department to see what your options are regarding permits and requirements for your location before you do anything.
