Results 1 to 8 of 8
    May 2009
    Default 1" threaded copper union leaking
    I'm wondering what the proper way is to install a "ELKHART 33584 UNION C TO C 1" COPPER" (or similar) fitting to keep it from leaking
    I had to replace the house water shut-off valve, and I had lots of trouble soldering due to the bending stresses of the existing pipes, so I cut the line downsteam and used a 1" copper threaded union to allow me to solder the joints in free air, then screw the last joint together.
    The union uses a simple rounded seat and mating rounded head on the two pieces, and when I first assembled the joint and turned the water on, the joint leaked profusely through the threads. I took it apart used some teflon tape wrapped partly around the thread, and partly lapping into the seat of the joint.
    After turning on the water, I got only a little slow drip, and with time it seems to be stopping.
    Is there some other trick I should have used?
    Thanks
    Photos attached
ID:	2426   Click image for larger version.
    612
    Default Re: 1" threaded copper union leaking
    I prefer to use pipe dope rather than teflon tape. And the teflon tape should not be on the seat of the connection. I am assuming you used two good size wrenches to to really tighten the fitting.
    However, it may not have been your fault at all. The cheaper fittings bought from a big box store supplied from China have become known for "hit or miss" threading. I have read on many forums frustrated users reporting that the threading on some parts are not machined well enough to allow a tight, leak free fit. It's probably a case of 90% good, 10% bad, but it's the 10% that people take the time to post about.
    1,643
    Only the seat of the union is intended to provide a seal. The threads are not meant to seal; they are only there to provide a mechanically strong connection. The seats should provide a good seal with just metal-to-metal contact; no compound or tape necessary.
    If the union is not sealing, then the seats are not mating properly. As bp21901 says, it may be a poor-quality union.
    May 2009
    I did not use pipe dope - the way I wrapped the teflon tape, it overlapped into the seating area by just a small amount.
    After the joint sat a while, the dripping has stopped, now it's just a "cold sweat" of moisture. For now, I'm going to leave it as-is and monitor. Fortunately, as you can see in my pic, I'm not lying on my back under the house to work on it, it's waist-high in an alcove under the stairwell, so it's easy to check on.
    Maybe next weekend I'll give the joint another crank with wrenches - I admit I just used channel-locks on the nut. With a bit of re-tourqing it should be OK. I may even open it up and put some pipe dope in there.
    Thanks for the advice.
    May 2009
    By the way...
    The Union I got from Home Depot is identified with the logo:
    Streamline Mueller Industries, Made In USA, Fulton MS
    612
    ***, you got one made in USA, that may be a museum piece!
    I would get a couple pipe wrenches and very firmly, by pushing one and pulling the other, try to get a leeeettle extra snugness out of the union fitting. I would bet that will take care of the drip.
    You just have to "persuade" that drip to leave town!
