    May 2010
    Default What type of plumbing?
    I am needing to do some plumbing repairs to a manufactured homes kitchen sink plumbing. The incoming plumbing is a white, small diameter, flexible tubing that looks like PEX, but elbow connections that branch from the lines look to be glued. Shut off valves are grey PB that attach to the white tubing via a threaded connection. The outlet from the valve is a compression fitting with more of the white flexible pipe. How can I identify this white tubing? Can I assume it is PEX or is there another type of tubing?
    2,969
    Default Re: What type of plumbing?
    "Pex" has become an umbrella term which includes many brands of flexible piping.
    Contacting the home manufacturer will give you best guidance since I can't see under your sink from here. Even if I stand on my chair.
    7,078
    Yes, it is probably PEX or similar. What is going to frost your nuts is that it will likely be an oddball size/diameter, which means that you will ONLY find replacement materials and fittings at a mobile home supply/repair facility. If you can use standard replacement materials, great, but don't expect it.
    Jul 2009
    Washington state
    186
    Sounds similar to the plumbing in an RV.
