Results 1 to 9 of 9
    Aug 2013
    Default Hot water through cold water side
    When flushing toilet we get hot water out of cold water side of bathroom faucet what is the problem?
    7,762
    Default Re: Hot water through cold water side
    When you flush the toilet, hot water comes out of the cold side in the sink? Is the cold valve shut?
    Aug 2013
    This may mean that the diaphragm in the pressure balancing shower valve has broken, allowing hot water to flow into the cold water lines when there is a sudden drop in pressure such as flushing the toilet.
    Aug 2013
    We open it to wash hands
    Aug 2013
    [QUOTE=dj1;281582]When you flush the toilet, hot water comes out of the cold side in the sink? Is the cold valve close?
    Cold water valve is open going into hot water heater,we flush toilet go to wash hands turns on cold water side of faucet and get hot water out.
    7,762
    Check and see if the supply lines under the sink are routed correctly. That means: hot from the wall to hot side of faucet, cold from the wall to the cold side of the faucet.
    2,697
    Quote Originally Posted by sel84 View Post
    I think this is it- Richard showed a similar situation on ATOH The only other thing I can think of is that the pressure drop in the cold when flushing may not be dropping equally in the hot side, same as with a flush-scald shower problem, but the OP said hot was coming from the cold line so I think sel84 got it right.
    1,890
    When you flush the toilet, the water flows so fast that the friction in the pipes causes it to heat up?
    (Didn't think so. It's probably a faulty shower valve or another single-handle faucet, as others have suggested.)
    6,023
    I agree with sel84.
