    Aug 2013
    Default Shower base and wall waterproofing
    I am new here so please bear with me as I learn the ropes. I am building a shower stall with a mud bed where a tub used to be. The mud bed is in, utilizing the rubber sheeting and weep hole drain system. The walls are up with Durock concrete board but I just learned about installing plastic or some kind of waterproof barrier on the studs behind the concrete board. I know I can band-aid that by applying a membrane like Hydro Ban, Redgard and the like but, my question is, seeing the mudbed is installed properly, do I just do the walls with the Redgard or continue accross the mudbed/floor? Thanks ahead of time for your reply. BILL
    Aug 2013
    Default Re: Shower base and wall waterproofing
    there is a video on youtube about redgard that i saw and you can use this on walls and your mud no water will pass this . they said not to use any thing behind the backer board this will give you a mould proplem. I am going to use this in my bath reno
    3,155
    No, do not add a second waterproofing layer to the floor.
    Did you install a pre-slope of ceement under the vinyl liner ?
