    May 2009
    Unhappy Heat buildup in garage
    Recently moved into a newer home (insulated concrete foam) and noticed as the weather has warmed how much hotter it is in the garage. Attic above garage is not insulated, rest of the house is. Should I insulate this, or install an attic fan? There is no attic fan in the home.
    San Diego, CA
    367
    Default Re: Heat buildup in garage
    I'd go ahead and insulate it. It should help somewhat. Also you might look at which way your garage door is facing. If it's on the West side of the house, you might be getting the afternoon sun on it. If it's a metal door, it'll transmit that heat pretty quickly. Not sure how much money you want to spend on the garage temperature but insulation is pretty cheap to start with.
    Good Luck.
    May 2009
    Thanks for the courtesy of a reply, I appreciate it.
    Aug 2009
    30
    If it is west facing you could simply get a insulated door and that would help immensely.
    2009 kitchen remodel warrior
    asbolute black granite
    Antique White Hidden Content
    Travertine 18" x 18" floor tiles.
    It looks Great!!
