Results 1 to 8 of 8
    Aug 2013
    11
    Default Venting bathroom without attic access in flat roofed house
    Just got a 1923-ish house, doing some work on it, and trying to figure out the best way to vent the bathrooms. Neither has any venting at all, and there's no access to the attic space. It's only about 18-24" tall, so I guess it's more of an attic crawl space? Either way, not sure how to go about running any duct short of installing an access hatch and crawling on in.
    We have those old spanish-style terracotta attic vents - could I finagle a 4" vent into that from within the house without having to climb up? I'm in LA, and it's a stucco house with a flat roof, so moisture isn't as much of a concern as it ordinarily would be.
    7,762
    Default Re: Venting bathroom without attic access in flat roofed house
    Those terracotta vents are most likely sewer vents, and you may not connect your bathroom vent into them.
    Better, try to vent through the roof. Simply remove some of the roofing materials above the location of the venting unit, drop a vent down and connect to the unit at the ceiling and make sure it extends about a foot above the roof. From the unit to the rigid vent (maybe a foot or two long) use a flex vent.
    You also need electric power to the unit and a wall switch.
    Finish the job by finishing the roof.
    Aug 2013
    11
    The terracotta pipes are definitely not sewer vents - they just open straight into the attic crawlspace. (We have the ceiling open for unrelated reno right now and you can see straight outside if you look up through them.) I'm hoping to avoid doing any penetration to the roof, for the usual reasons, but it's certainly an option if there's no alternative. I was hoping I could push a rigid vent assembly up through the attic, then pull it into the terracotta from exterior. This may be pie in the sky though!
    7,762
    What diameter are those terracotta vents and how many vents do you have of this kind?
    3,188
    A Broan or Panasonic vent will give you a smallish but usable space to work with to get a vent up through the roof. These vents require ~ a 12 x 12 hole. Combining that with the roof access, you can make it happen.
    Flashing is critical
    2,721
    It seems the existing vents you refer to are for under-roof ventilation. So long as you have enough ventilation with them after the bath vent is snaked in, then all you have to worry about is weatherproofing the bath vent. You may need someone familiar with terra-cotta roofs in your area to determine whether the venting is adequate.
    Being in LA, I'm sure you are supposed to have some kind of permit to do the work you are planning and currently doing- all big cities are like that. Whether you wish to get one is your choice but if it were me I'd just tell the roofer to give me a roof venting assessment from the outside and leave the rest unspoken of. If he said it was substandard or marginal I might see if I could vent through a wall instead. And while you can get to it, insulate- in SoCal's heat you need all the help you can get!
