    Apr 2012
    143
    Default Wedge Expansion Anchor (Bolt)
    Question: can wedge expansion expansion anchor bolts be uninstalled (removed).
    I am securing a fire safe (60" H, 435 lbs) to my garage floor -- manufacturer recommends 4 "wedge anchors" of minimum 3" long & 9/16" dia.
    Once installed, can the anchors be "unexpanded" for removal, to move the safe ??
    I suppose I can buy 4, hand tight one a little, and reverse it to see of the wedge elbow retracts. . .
    7,048
    Default Re: Wedge Expansion Anchor (Bolt)
    Generally, no, the wedges do as they are supposed to and secure the bolt in the hole, what you can do is simply cut them off and leave it or tap the bolt shank down into the hole and fill with a bit of mortar.
    6,530
    You see them on city concrete sidewalks, in places where they used to have newsstands or mail boxes which were removed. The bolts cut off and ground to the concrete.
    Apr 2012
    143
    How about Tapcon concrete/masonry screws ? I have never used them, and don't know if they come in the size needed, especially the diameter.
    Anyone unscrewed them ?
    Thanks.
    1,004
    i use tapcon screws all the time....no reason not to use them and you can remove them later
    5,797
    Or you could install lead rawl plugs The bolt can be installed and unscrewed later.
