Results 1 to 10 of 14
    17
    Default Deteriorating cement board clapboards.
    The clapboards near the stairs are disintegrating. I believe they are fiber cement board. The stairs are stone, and lead to the front door. I'm not sure what to do to prevent this from happening again. We thought about flashing, but am not sure how to do it, or if it would look right.
    This house was recently purchased by a friend. I've done other repairs and interior painting, but am stuck on this one.
    http://flic.kr/p/fioFLP
    http://flic.kr/p/fioFKT
    I've tried to embed the photos in the message but couldn't do it. Kept getting invalid image. Sorry about that.
    1,808
    Default Re: Deteriorating cement board clapboards.
    What is the nature of the deterioration? Cementboard, at least Hardi-Plank, is highly resistive to water damage. the lesser fiberboard products will turn revert to sawdust when wet.
    1,004
    i can't open your pictures but from what you've described i highly doubt that you have fiber cement clapboards.
    6,751
    digger,
    Try posting a photo on photobucket.com and then give us the link details.
    17
    [/URL]
    [/URL]
    I'm not home right now, but i will check the extra clapboard that were stored under the deck. I think the previous owner let snow stay on the steps in that area.I thought constant wetness could cause this kind of damage.
    1,004
    i'm not saying that it's not cement board but it doesn't look like it is in the picture you posted. you can put fiber cement clapboards in the deep end of a swimming pool for a year, let them dry out for a day then install them and they'll be fine. it looks like the paint is failing where the claps meet the steps.
    Jun 2009
    332
    If you are in an area that has snow and ice and salt or a deicing fluid was used it would cause the cement board to break down.
    1,004
    Quote Originally Posted by Clarence View Post
    good point, didn't think of that....and that's true
    2,969
    flashing will involve some air room for the space to dry. If snow salt is a factor, lead flashing is in order.
    1,213
    Hardi recommends not placing their products in the splash zone, but having 2" vertical space above any horizontal surface. You run flashing down to the steps instead of cement board.
    Casey
