    Jul 2013
    Central IL
    Default Shear Wall in 100 Yeal Old House
    I am remodeling a house build around 1910.
    Wall configuration from inside to outside: Plaster, ship lath (sp?) 2x4 studs with blown in insulation in the bays, wood lap siding, some type of asphalt siding, and vinyl siding.
    I have removed the interior plaster, ship lath and insulation in approximately 1/2 of the house.
    * What I am calling ship lath = approximately 1" thick tongue in groove wood boards that were attached horizontally to all opened up exterior walls on the interior side only.
    My original plan was to remove all exterior siding down to studs and attach new plywood, add foam boards and new exterior siding.
    My plans have now changed to - finish interior, add new windows and replace exterior vinyl.
    My question is -what to do about structural integrity of exterior walls?
    I read an article about creating "insert shear panels" by making panels out of 2x4's and plywood and inserting them between the wall studs.
    This seemed like a lot of work, but a possibility as I am considering insulating as follows: 3 layers of cotton batt (first layer: in 2x4 exterior wall, 2nd layer: between exterior wall and new interior wall, 3rd layer: in new 2x4 interior wall. This would be finished with Dry Right (by CertainTeed) and then sheet rock over it. I was thinking the plywood would also block some air flow as there is no plywood on the exterior of the house.
    The second option would be to insulate the original exterior wall, attach 1/2 - 3/4" plywood to the interior (where the ship lath was originally attached), apply Dry Right (by CertainTeed) and then sheet rock over it.
    I know that would be alot cheaper, but I am very tired of being cold in this old house.
    Any suggestions? All would be greatly appreciated.
    2,969
    Default Re: Shear Wall in 100 Yeal Old House
    You are on the right track, but you've passed the station a bit.
    I live in a similarly built home so I have first hand experience with this method of construction. You should have done the outside first, but that ship has sailed. To be able to do the outside I would;
    1- Install temporary sheets of 1/2" plywood on the inside of the house where you want to replace the siding. This will give you your sheer strength. If need be, brace the house to correct any tilt in the walls before screwing on the panels. Not to be confused with house leveling which is done before this step.
    2- Remove the siding in that section
    3- Install new framing if needed for doors and windows
    4- install new plywood (required on the corners here, on all surfaces in FEMA hurricane zone 1)
    5- Install new siding.
    6- move the temporary panels on the inside to the next section to be sided.
    You can of course strip the entire house to the bare studs in order to make all the framing changes and corrections, but you'll need to add a serious amount of cross bracing as you go along to keep the house standing. This cross bracing is routinely done when framing a new house to keep the weight of the roof from collapsing the structure.
    2,969
    oh and the correct term is 'ship lap' as the material is lapped over the next piece
