Results 1 to 9 of 9
    Jul 2013
    Default Walls near chimney
    I am building a closet in our office to make it a bedroom. The chimney runs through the room. While the bricks are only warm to the touch after hours of a raging fire, I suspect there are some regulations about how close I can build a wall to the chimney.
    Is there a gap that must exist between the chimney and the new closet wall? Are there any firestop materials that must be used on the side of the wall closest to the chimney?
    Thanks!
    6,598
    Default Re: Walls near chimney
    I believe that you will need a permit for such a wall. Contact your building department and ask them.
    Jul 2013
    The wall is not load bearing so a permit is not necessary in this case.
    1,604
    Generally cumbustible materials should be kept 1" away from a masonry chimney you describe. Assuming their is fireblocking at the floor & ceiling, no additional fireblocking is required. I am on the east coast, so what so. cal. regulations say about the subject are beyond me. It never hurts to check with the building depaqrtment.
    Sep 2012
    Boston
    1,004
    just because you're not moving a load bearing wall doesn't mean that you don't need a building permit.
    Jul 2013
    Thanks ed21, that is exactly what I was looking for. I sort of assumed that just by using common sense but didn't know if there was any "best practice" things that I should know before getting started.
    After reviewing the codes in NC, it states that a permit is required for:
    Construction, additions, remodeling, repairs, replacements, upgrades or any project over $5,000
    Accessory structures such as detached garages, sheds larger than 12 feet, platforms, green houses, etc.
    Any project that involves structural support changes (roof or floor), load bearing walls, screened porches, decks, and balcony projects
    Mechanical permit for replacing a hot water heater, duct running, ventilation, etc.
    Plumbing permit for running lines or replacing shower and/or bath tub enclosures
    Electrical permit for building projects that require electrical wiring such as installing ceiling fans, electrical outlets and overhead lighting
    Landscape Irrigation system installation
    Retaining walls that stand over four feet in height
    Interior and exterior fire place and fire place inserts
    Sky Lights
    Re-roofing, if third layer of shingles
    Exterior Siding
    None of this criteria fits the job that I am doing.
    2,969
    You're lucky. We need a permit to blow our noses.
    Every chimney I have met has an air gap between the studs and the masonry. Including the 1927 brick chimney in my house which runs up the kitchen / dining room wall.
    1,180
    Metal studs and 5/8" type X drywall can be zero-clearance.
    Casey
    2,118
    You speak of "NC codes" but you need to check locally as well. Here in SC counties deal with this, each one is different, and the cities in those counties often have far more restrictive language as well as some very nasty fines for un-permitted work. My county states that if the project value is $200 or more you have to pull a permit- just about every painter violates this law without problems but let me build you a small fence or deck and I'll get busted
    You may want to get a permit and inspection anyway if you can, for if a fire were to occur, your house insurance claim might be denied. With the permit and inspection that won't happen. Just sayin, neighbor
