    Aug 2013
    Default Adding a ridge vent to an existing comp roof
    I have an architectural comp roof (I believe some call it a lifetime roof others a 50 year roof). Is it possible to add a ridge vent? I need to correctly vent a vaulted ceiling. My previous post about correct venting was answered but it did not say whether a ridge vent could be added.
    7,762
    Default Re: Adding a ridge vent to an existing comp roof
    The simple answer is yes,
    3,188
    Remove the current ridge cap shingles
    Use a circular saw to cut through the shingles and plywood, about 2 inches on either side of the ridge, stopping short of the edges and any eaves.
    Install your new ridge cap
    Install your new shingles
    Dab some caulk on those last 4 roofing nails.
    2,721
    Don't forget that a ridge vent is only half the system- you need proper eave ventilation too. On many older homes this may be marginal or non-existant so it's worth checking while you're at it.
    7,762
    Correct procedure, except for dimensional/architectual shingles, you need to cut more than 2".
    3,188
    True, plus different ridge vent manufacturers will have different opening widths at the ridge
