    Jun 2013
    Unhappy Leaking skylight every two years
    I have a three season porch with a peak roof and a skylight on each side of the peak roof. The roof is made of a thin sheet of aluminum four inches of foam, then another thin sheet of aluminum. Every two years I have to unscrew, clean the surface of the roof and the skylight...Re-silicone surface, then screw the skylight back down. After two years the skylight re-leaks...I was wondering is there a way to make a gasket for the skylight that would last longer than two years before leaking again?
    Sep 2012
    Boston
    1,004
    Default Re: Leaking skylight every two years
    Grace Ice and Water Shield, it's sold at your local lumber yard and the big box stores
    6,598
    Depending on where it's leaking exactly, your problem could also be the skylight installation and flashing, the caulking type or the caulking application.
    A gasket (foam or rubber) won't solve anything, it will deteriorate quickly.
    2,969
    Try switching to a urethane caulk.
    2,118
    Another thing you could try is window-setting tape like is used on RV's. It's mean for sticking and sealing and it's made for outdoor weather on metal-to-metal surfaces. On RV's it lasts at least ten years, often a lot longer. I have become a fan of Duo-Seal "Siroflex" caulking. It's a silicone/urethane blend and it adheres like nothing else I've ever seen. Perhaps it will do the job for you but I haven't tried it on anything similar.
    Jun 2013
    Thank you for all your great ideas... I will give them all a try...
    First up will be'
    I will try the window-setting tape like is used on RV's. It is made for outdoor weather on metal-to-metal surfaces
    With a possible ten year pay off.... I will let you all know how it works...
