    Jul 2013
    Default Moen posi temp cartridge shower comes on without pulling knob on spout
    Why does my shower turn on in certain places as I dial in the temperature of the bath.? It happens before I even pull the knob on the tub spout !! I replaced the moen 1222 posi temp cartridge hoping for a solution. Not fixed. So frustrating. What do I do?
    Default Re: Moen posi temp cartridge shower comes on without pulling knob on spout
    Moen 1222 Posi temp is a pressure balance faucet. The water comes on when you rotate the handle left or right, not by pulling it out. No water flows when the handle points down.
    South*East
    1,259
    That will happen is PEX or CPVC pipe was used between the faucet and the tub spout. Both PEX and CPVE have a smaller OD than copper. I believe the instructions on the faucet have a warning about use PEX or CPVC.
    John
