    Jul 2013
    Question Low Water Pressure on Well,Possibly Due to Stupidity.
    A couple of months ago I changed the pressure switch on my well. To relieve the pressure I opened a tap and let it run for a few minutes with the power to the pump off. When I removed the switch, water went everywhere.I did get the switch in place and rewired.Since then, the switch "jumps" (as it did before) and water pressure is little better than a medium trickle. How much air can be readded to the tank, if necessary?
    6,115
    Default Re: Low Water Pressure on Well,Possibly Due to Stupidity.
    If you are talking about a bladder tank, you have to drain the system and add air to the top to a point 2 lbs less than the low setting on the switch.
