    Mar 2012
    Copper Center, Alaska
    Default Hot Air Ventilation From Gas Range
    Greetings! We just installed a new GE gas range model JGBS18. When we use the oven we feel hot air blowing from beneath the timer on the control panel, and the cooktop gets very hot. Is this normal? Anything we can do about it? Our last range did not put out heat nearly as bad as this.
    Thanks!
    Default Re: Hot Air Ventilation From Gas Range
    Yes that's normal.
