Thread: Mildew
    Jul 2013
    Default Mildew
    What is the best way to remove mildew from pavers without damaging them or changing the color?
    Default Re: Mildew
    First power wash the pavers. Keep in mind that washing will remove the sand between the pavers, which you will need to add later.
    You don't want to use bleach, it might change the finish on the pavers. Instead prepare a solution of warm water and dish detergent, and pour on the pavers while brushing with a small brush. A lot of labor. Wear gloves.
