Results 1 to 10 of 11
    Jul 2013
    Default flooring or walls first?
    Bought a house that is roughed out inside. Do I lay floors first or sheetrock first? Does it matter other than messing up the floors with sheetrock dust?
    7,231
    Default Re: flooring or walls first?
    Finished floors will always be the last thing you do. Get all your electrical and plumbing dealt with, finish the walls, then install doors. I would be inclined to paint at this point, then install cabinets. Floors can be done before or after cabinets, your choice.
    Jun 2013
    Chicago burbs
    7
    Get your drywall finished and at least primed before you do your tile
    6,736
    That's right: drywall first. Don't sit the drywall on the floor, hang it about 1/2" higher than the floor.
    2,969
    When possible we like to get the paint on the walls then install the hard flooring, then install the trim / baseboards. You'll get a neater final product if you can keep the subs from damaging the floors.
    Jun 2013
    Chicago burbs
    7
    Pierce,
    I'm not familiar with your phrase "floor stripping?" Are you talking about hardwood flooring?
    Jul 2013
    Does drywall have to breathe?? Is that why it should be 1/2" higher then the floor
    7,231
    Quote Originally Posted by daycarelady View Post
    The gap is to help prevent wicking from slabs or wet subfloor. It also gives carpet a place to key into which helps to lock it in place.
    1,212
    Quote Originally Posted by Rickey6967 View Post
    Well dude plumbing and electrical work always first after completed it then you flooring work because it is complicated work dude am i right buddy????
    On rough-in: Drains, then (rigid) ducts, then copper supply lines, THEN electrician. Wires are bendy, the aforementioned items are not.
    But yeah, in general hold the hardwoods until much later in the process, the exception being kitchens, where cabinets are best delayed until after the hardwood is down, sanded, and has at least a first coat; less risk of bumping the cabinets, which after all are the most expensive item.
    Casey
    1,671
    Vacuum the floors immediately before each phase of painting, especially if you're spraying the paint on. This will prevent dust from getting into the paint.
