    Jul 2013
    Default putting soffit on a fieldstone cottage
    I have a field stone cottage. The soffit that is currently there is wood and I want to replace it with aluminum.
    My problem is on the inside of the old soffit it goes right up against the field stones. What would you suggest as a method to attached the inside j strip, I was thinking of a narrow wooden strip attached to the existing soffit and then attach the j strip to it. Is there anything else that I might consider or am I missing something.
    Thanks in advance.
    Jun 2009
    NY
    35
    Default Re: putting soffit on a fieldstone cottage
    i like open rafters for the tails..looks better and eliminates the problem
    http://expediter-nyc.com
    Jul 2013
    Sorry I am not sure what you mean, 'rafters' can you explain.
    7,914
    Quote Originally Posted by canann View Post
    He means leaving the rafter tails exposed, as opposed to enclosing with wood or other material. He apparently missed that it's already enclosed with wood.
    I personally would leave the wood, repair/replace any damage, and paint it. Because it is a soffit, it is not subjected to the elements, therefore it does not need to be clad in aluminum, vinyl, or any other such nonsense.
    Jul 2013
    Thanks for the clarification, we are getting older and find it harder to paint the soffit as it is a big job, that is why we want to change it to a no/low maintenance.
    7,723
    Soffits are not exposed to the sun and the rain, and require much less care than the house exterior. It's considered "low maintenance" area.
    You can paint it yourself, on your own pace, or hire a handyman/painter to do it. Really no big deal.
