    Mar 2011
    15
    Default Help with removing wooden window sash
    I want to paint my 1980's wood windows and would like to remove them to do an accurate job.
    These are somewhat old wood windows (not the ones with ropes) that are slotted on the side and move along slotted runners.
    In my kitchen, I can see there is some sort of notch in the window slot that is preventing me from squeezing the window out the jamb. In the bedroom though, the runners have an outside lip that encloses the entire sash - these look much harder to remove.
    Any help is greatly appreciated.
    1,173
    Default Re: Help with removing wooden window sash
    The aluminum tracks come out. The retrofit kind I'm familiar with have a nail top and bottom, and both tracks and both sash come out together. The wooden stop molding on the room side need to be removed first.
    Casey
