    Jul 2008
    49
    Default Is pre drilling cement board siding required
    do you have to pre drill cement board siding prior to installing a lag screw. If you don't pre drill what would happen.
    1,002
    Default Re: Is pre drilling cement board siding required
    installing a lag screw in almost anything requires predrilling. if you're "nailing" up cement board siding the answer is no, it does not have to be predrilled.
    nova scotia, canada
    1,522
    if your gun nailing no it doesnt need to be pre drilled.. if your hand nailing you have to pre drill at the ends otherwise it will shatter
    1,897
    Since you're installing lag screws, you really want the screws to be biting into the wood behind the siding, since the siding itself isn't going to have the structural integrity to hold any weight by itself. So yes, you should predrill through the siding. The pilot hole through the siding should be equal to the outer diameter of the screw threads; the pilot hole in the wood behind should be equal to the inner diameter of the threads (or slightly smaller). Failing to at least predrill the siding could cause a blowout of the fiber cement product.
    Jul 2008
    49
    All,
    Thank you...One more question should i use a masonry drill bit.
    1,002
    yes, into the cement board.....no for the house sheathing
    nova scotia, canada
    1,522
    if you can find a store that sells cheap bulk drill bits those will work fine too. 1/8 " is what i use
