Results 11 to 20 of 23
  1. #11
    1,004
    Default Re: Installing HardiPlank over Existing Siding??
    what year was your house built? 1795? are you sure about that?
  2. #12
    Jun 2013
    13
    1920's. That is what I am being told. Going to see for myself this morning. Will let you know.
  3. #13
    Jun 2013
    13
    I saw it for myself. There is NO sheathing/plywood on the outside of the studs. What would you do now? Also, what insulation would you add? HELP!!!
  4. #14
    nova scotia, canada
    1,522
    well, your going to have to strip down the old siding. .insulate teh cavitys then sheath it.. then put house wrap on then the rain screen.. it looks like you bought a money pit
  5. #15
    6,598
    DeniseTW,
    Now you understand why we recommended to rip and remove the existing siding in the first place:
    1. To uncover what you go there.
    2. To make repairs, to make changes and to make improvements.
    3. To bring everything up to code.
    4. To have the correct surface for the new hardiplanks.
    Costly? yes, but worth it.
  6. #16
    Jun 2013
    13
    Yep looks that way. What type of insulation would you use & how to install it other than the rolled fiberglass type? We are going to work on one side at a time in order to preserve the integrity of the house. Thanks for your input.
  7. #17
    6,598
    Rolled insulation is fine. Check owenscorning.com for the R value in your area.
  8. #18
    May 2012
    137
    Dow Chemicals has a "FROTH" Pak which contains the two chemicals needed for spray foam, which can insulate more fully instead of rolled insulation. And, you can do it yourself.
  9. #19
    Jun 2013
    13
    Quote Originally Posted by daspyda View Post
    Thanks, have you ever used it? The reviews I've been able to find are less than favorable.
  10. #20
    May 2012
    137
    Not yet. However, most of the pro reno shows on HGTV and DIY Network use foam in their projects and have pronounced it superior to standard insulation.
