Results 1 to 10 of 10
    Jun 2013
    12
    Default Is caulking necessary?
    Hi all, today I removed some caulking from between the tile and tub on a tub/shower. It suddenly donned on me that when the water gets through the grout/cement board and goes back to the tub, how does it get back in if you have that interface caulked? Then I did some googling and found this.....
    "It doesnít need to be caulked at all. Caulking at the bottom of the tub is not a required step, itís more aesthetic than anything else. Although it does contain more water in front of the surface of the tile, you donít NEED it."
    Even if I left little area's uncaulked (weep holes) wouldn't the water get in behind the caulk and eventually get moldy?
    Thanks,
    Mike
    7,635
    Default Re: Is caulking necessary?
    Mike, caulk it. I would.
    7,860
    True, grout lines can fail and allow moisture behind the tile, however it is a falacy that it will find it's way to the bottom edge and seep out on its own. What it will do is loosen the grip of the mastic holding the tile to the wall, as well as mold/mildew behind the tile. If you leave the tub/tile joint uncaulked, it too will allow moisture behind the tile and cause mold/mildew and eventual tile failure. Caulking is more than aesthetic, use it and make sure that the joint stays secure. If you notice the caulking starting to crack or fail, remove it and recaulk.
    1,002
    spruce is 100% correct. who ever wrote what you read is wrong.
    1,354
    AArgh! You never put tub-surround or shower tile up with mastic! Thinset mortar only. Mastic-based failures are far more prevalent than successes.
    I think there is some truth to the idea that in the old days with 1 1/4" thick mud job tub surrounds, the caulk of marginal quality back then, it was a "wash".
    Remember grout lets moisture in AND back out again, it's a revolving door, so caulk at the bottom is not trapping vast amounts of water because it can evaporate via alternate routes.
    Casey
    Jun 2013
    12
    Thanks everyone,
    Just trying to understand the water/moisture migratory path. I'm told that the water hits the tile, seeps through the grout to the cement board, seeps through the cement board and hits whatever barrier where it runs down to inside the lip of the tub or pan. If this is correct, then my confusion was how can the water make it to the drain if you caulk the exit (between tile and tub/pan)?
    Is this how the mold was caused under my caulk?
    Mike
