    Jun 2013
    Question Sky Light leaking...
    I would like any information about a fix that would last longer than one year.
    I have an enclosed porch with two skylight's opposite from each other.
    The enclosed porch looks like some sort of kit.
    The roof is constructed of panels 8 x 4...four on each side of the roof peak.
    They are made of six inches of harden foam with a thin aluminum skin.
    The contractor cut a skylight out of one of these for each side of the roof peak.
    Every year I have to un-bolt the skylight, scrap and clean the area (Make sure there is no old silicon left from the past year). The skylight leaks every year when it rains heavy...
    Does any have a way to make these two skylight leak proof?
    I was thinking maybe I could get a sheet of roofing leak barrier, then seal it with I do not know at this time.
    Any suggestions would be helpful.
    Thanks all....
    Default Re: Sky Light leaking...
    There are a few kinds of skylights and a few kinds of leaks - you have to find out where the water is coming from. Basically, a good roofer will roof around a skylight the same way he does around a chimney.
    let me suggest you watch some demonstrations on YouTube and if you find the job too hard, get a roofer.
