Thread: pool pump
    142
    Default pool pump
    Does a pool pump need to work 24 hours a day or is it sufficient to stop it after working for 12 hours? Neigbours
    are complaining of noise coming from pump especially at night.
    Thanks for your advice.
    Mar 2013
    WI
    112
    Default Re: pool pump
    A pump does NOT need to run 24/7.
    I run mine during daylight hours, as moving water is harder for algae to grow in.
    IF we swim at night I run the pump for about another 1/2 hour after we get out of the water.
    This is also considering that the pump/filter is not undersized for your pool though.
    Also,pumps should be fairly quiet. Make sure no leaves,pine needles,debris are caught in the impeller.
    142
    Is there a possibility to cover pool pump with a box of some kind? I may be able to construct wood box around it and over it. It is an annoying buzz. Unfortunately, I'd never have a pool again due to noise of the pump . Do you have a solution?
    Thanks again.
    7,627
    You can do it, but to muffle some of the pump noise more effectively, build a block wall around it.
    Mar 2013
    WI
    112
    I planted bushes around mine,but that is more to hide it out of sight.
    I have seen people build little sheds over their pumps to hide them. I would give it a little ventilation as the motors do get hot.
    Again,no need to run it continually,unless the pool is used 24 hours a day. Nothing wrong with running it all the time,I just don't want the extra expense on my electric bill.
    If you have others that you know with a pool you may want to see what brands they use. Some may be quieter than others. I can barely hear mine running 15 ft. away,and this is for a pretty big in-ground pool.
