Results 1 to 8 of 8
Thread: double flushing
    145
    Default double flushing
    I need to flush twice in order for the toilet to empty the bowl. What problem may it have? I tried a plunger but that doesn't SEEM O BE HE PROBLEM. Any HELP WOULD BE APPRECIATD.
    Thanks
    Mar 2013
    WI
    112
    Default Re: double flushing
    Low flow toilet? If so, that's most if not all the problem.
    South*East
    1,252
    It could be that the bowl isn't refilling after the previous flush. Is the refill tube putting water into the overflow tube?
    John
    7,762
    What kind of toilet/tank is it?
    Lift the tank cover and flush. Is the entire tank go down? is it filling up to the desired height?
    145
    Yes the tank does fill up. It is not low flow toilet.
    7,762
    Have you used a toilet auger? You could have some blockage inside the toilet, that a plunger can't remove.
    I'd remove the toilet, bring it outside the house and clean it in the yard.
    Jun 2013
    what are you eating
    sorry couldn't resist
    7,762
    Quote Originally Posted by mske390 View Post
    what are you eating
    That was cute...but a blockage or an obstruction is usually NOT due to an organic matter in the toilet or the drain line.
    As a landlord, I've seen toilets with things like cloth, diapers, toys, straws, and you guessed it, condoms causing stoppages.
