    Apr 2009
    6
    Default Ceiling fan drip
    Hello,
    I have recently moved into a house with a flat roof and have noticed that when it rains the ceiling fan in the upstairs bathroom drips.
    I've noticed that the water is coming in on the outside of the duct and I can see that some water has spread into the drywall.
    I have been onto the roof and I can't see any holes in the duct or in the roof around the duct, although the duct is quite rusty.
    Is this a common problem for a ceiling fan? Has anyone had anything similar and if so, what's the cure?
    Thanks,
    Chris
    Feb 2009
    693
    Default Re: Ceiling fan drip
    Chris,
    You may not be able to see it but you have a roof leak.
    Are you suggesting your ceiling fan creates water and drips when it rains?
    Apr 2009
    158
    Wink Re: Ceiling fan drip
    maybe it runs on hydrogen?
    Apr 2009
    6
    NEC,
    I would like to think that my ceiling fan was creating this water, but I can see that the truth is too obvious for me to ignore-I have a leaking roof. So if the leak isn't obvious to the eye, is there a way to find out where it is? By the slow drip coming through it must be a small crack, so if I find the leak can I seal it with something, or is this a job for a contractor?
    Thanks for you reply btw,
    Chris
    Feb 2009
    693
    Love ya Chris, really do.
    I would buy a gallon of "roof mastic" and a cheap brush from a home supplier and coat the "ell" out of every seam on your roof.
    Go from there if it still leaks.
