Results 1 to 10 of 13
    Apr 2012
    212
    Question Small Subpanel Replacement
    I'm trying to renovate my garage. it has a small sub-panel in it (see picture below). It measures 6 1/2 X 6 1/2. I would like to update it but I can't make the opening any wider. Does anyone know of any company that makes a sub-panel this small?
    5,825
    Default Re: Small Subpanel Replacement
    Apr 2012
    212
    Lightbulb Re: Small Subpanel Replacement
    Thanks Jack.
    It says "indoor". Is a garage considered "indoor"?
    6,694
    A box could be surface mounted, not just recessed. If that's the case, any box will do.
    Check with your local bldg dept.
    Sep 2012
    Boston
    1,004
    inside a garage IS considered indoors
    Apr 2012
    212
    Yes I understand, but I prefer recessed in this particular location.
    Apr 2012
    212
    Quote Originally Posted by MLB Construction View Post
    THANKS MLB Construction for the clarification
    Apr 2012
    212
    Question Re: Small Subpanel Replacement
    I'm going to run some new wire to the subpanel when I install it. There is not much of a load in the garage. The lighting consists of 5 LED lights (at 9 watts each) and two 15 amp receptacles. The attic has 3 LED lights @ 8 watts each. That is it. Running 8/3 should be more than enough correct?
    5,825
    Way oversize, unless you are planning for future expansion.
    Apr 2012
    212
    Wasn't really planning on future expansion. I have a 20 amp receptacle BUT it is on a separate circuit run straight from the main box.
    So 10/3 would be good enough?
