Results 1 to 8 of 8
    Jul 2009
    Washington state
    232
    Default Pegboard over drywall
    I want to split our shop area into two rooms by framing up a new wall. I plan to put pegboard on one side, and some sort of paneling in the other. Do I need to tape and sand the drywall that will be underneath, or can I just apply the paneling to it as is? I'm not concerned about cosmetics.
    7,762
    Default Re: Pegboard over drywall
    Pegboard hooks need space behind the boards, so if you have drywall behind, it won't work.
    6,023
    To meet fire code the drywall will need to be taped and muddied, however it will not need to be sanded. You will need to install spacer for the peg board.
    Jul 2009
    Washington state
    232
    Tape and mudding I don't mind. Good to know I can avoid sanding! and yeah, I know about the spacers. Thanks!
    8,002
    That only applies when the space abuts living space, a divider wall within the garage/shop would not be an issue. How many garage walls do you ever see drywalled unless it's a common wall with living space? In these parts, it's unheard of, unless you're a freak like me who likes the clean and finished look of a finished garage.
    Quote Originally Posted by queen60 View Post
    You could pegboard one side of the framing and drywall or panel (plywood is best for a shop wall ) the other. This would keep light from passing through the wall, improving aesthetics.
    6,023
    A.Spruce, the OP didn't say it was a garage, he said shop.
    8,002
    True enough, though I would still question the necessity of a firewall within the structure, especially if the new space won't be completely sealed off from the rest of the space.
    1,890
    There's also that matter that your "name" will be on it. Sixteen years from now, will you be proud when people say "queen60 built that wall?"
    However you do it, use your best craftsmanship.
