    Apr 2009
    Default Solid Iron Railing
    I want to remove my solid iron railing from the back porch. the post are inch and a half by inch and a half, and are imbeded in the concrete pad. I want to save the imbeded part of the railing post that are inthe concrete. What could I do to acomplish this mission. Or should I just cut them with a reciprocating saw flush with the concrete.
    thank you in advance for anyone that can give me some advice.
    Default Re: Solid Iron Railing
    You will either have to cut the posts or break the concrete.
    San Diego, CA
    Keep in mind that if you cut the post off, it'll leave a metal stub in the concrete. Exposed to air and moisture, it's going to rust and make a mess of the surrounding concrete. To stop that, you're going to have to either cover it up with a decorative cement something or cut it out.
    Good Luck.
