    May 2013
    Default Medicine Cabinet Mirrors - Issue with sliding
    I have an older home and I really like the old medicine cabinet. The issue is that the mirrors are a bear to open and shut. I can't help but believe that there is some sort of slide mechanism that might be missing. They just sit in a metal frame and slide back and forth - with effort. Does anyone know something I can insert under the mirrors to make them slide?
    Default Re: Medicine Cabinet Mirrors - Issue with sliding
    This might help: clean and lubricate the track.
    6,054
    You might try cleaning out the tracks, perhaps Q-tips and some alcohol. then spray the tracks with a dry lubricant or adding a Teflon Tape in the track.
