Thread: burst pump
    May 2013
    Default burst pump
    Hello, any info. on how to take a pump that was added to the plumbing under my mobile home, out, I mean I need to remove it as it leaks water under my home everywhere, I have unpluged the electric to run it, but water still must flow thru it to the rest of my home. I really would welcome the advice.
    Default Re: burst pump
    Depends, what was the purpose of the pump to begin with? If that need is no longer necessary, then yes, the pump can be removed. You may want to employ a plumber to do the job for you, as they will know how to either terminate the connections or splice the pieces back together so as not to disrupt water flow.
