Results 1 to 10 of 12
    May 2013
    Wexford
    Default Old Whirlpool washing machine
    Guys,
    Have an old Whirlpool machine approx 15 years old, need to replace the cp of that. Any suggestions?
    7,084
    Default Re: Old Whirlpool washing machine
    Find a manual on-line, locate the damaged part, price said part, then make determination if it's better to spend $ on part or replace machine. Personally, I'd be inclined to just replace the machine, at 15 years old, it's not got much life left in it anyway.
    6,598
    Personally, I wouldn't waste a minute searching for parts. Why?
    1. Let's say you found the part, 100% sure it will solve your problem. Knowing Whirlpool, it will cost a bunch. Say you buy it and the machine works...you still have a 15 y.o machine ready to go out anyway. And if it doesn't work...well you're out a couple of hundred. Even Whirlpool admits that Whirlpool machines won't last that long.
    2. Now, I doubt that you can find the part - discontinued, phased out - is what you will hear. Better luck looking in used machines, not just under Whirlpool, but about a dozen labels owned by them. But the search will be exhausting.
    I will look for a new machine.
    May 2013
    Wexford
    A new good Machine costs at least 800 while looking at the part i need to replace would be around 80 - 90 and the machine works perfectly apart from the CP which acts odd at times so i guess replacing would be a better option. I can get the exact CP from a couple of places
    7,084
    The thing is, you've still got an old machine, how long until the next thing goes out? I'm not trying to talk you into buying a new machine, just giving you a little real world experience. To me, $80-90 is a little much to invest into such an old machine, $50 I'd be willing to risk, maybe.
    We had a 10 year old washer, I forget the brand. The dial switch went out, and I replaced it for something like $75. Within a year, it smelled like it had a burning belt, changed the belts, plugged it in and the electronics smoked. To add insult to injury, new machines were about $150 less the year before we were forced to buy new.
    Apr 2012
    212
    Lightbulb Re: Old Whirlpool washing machine
    If he has the machine that I think he has (he hasn't verified this yet) then parts will be available for at least the next decade. Whirlpool own 80% of the market and they just spent a bundle retooling their factory to make this same basic machine for the next 15 years. Other than the way the machine looks and the name on the front, Whirlpool makes all of these machines; Roper, Estates, Maytag, Amana, Admiral and Kenmore
    Quote Originally Posted by keith3267
    Too bad the Maytag commercial washer isn't still available, it was cheap and ultra reliable.
    Maytag is owned by Whirlpool and uses the SAME design/parts. This same basic machine has been in production for around 17 years now. The only thing different between a Maytag and a Whirlpool is the marketing.
    1,750
    Quote Originally Posted by MyMilan View Post
    Maytag was acquired by Whirlpool in 2005. Prior to that, the Maytag Commercial washer was a staple of the line. As far as I know, none of the Maytag designs continued under Whirlpool, the Maytag factory was closed and Whirlpool began to put the Maytag label on their products.
    Apr 2012
    212
    Correct, they bought Maytag for 1.7 billion dollars. The deal was approved in March 2006. At the time Whirlpool also owned the KitchenAid and Roper brands. Maytag owned Amana and Jenn-Air, all of which are now owned by Whirlpool. They are now the world's biggest appliance maker. The Maytag uses the same design as all the other Whirlpool brands, only most use commercial-grade parts.
    May 2013
    Wexford
    It works fine apart from that, even with broken CP it works fine, just sometimes you press for drying and it starts with extra rinse option instead of drying. So may be look at pricing it out first then?
    Apr 2012
    212
    Quote Originally Posted by CSMartin View Post
    What is the model number of your machine? There is one that they make which is virtually indestructible. Other companies have tried to copy the design but have been sued. They still make this same basic design, only cosmetic differences. If I saw a picture or model number of what you have that would help.
