Results 1 to 9 of 9
    May 2013
    Unhappy Cracked plumbing
    I own rental property in Chapel Hill, NC, built in 1970 on a concrete slab. It is surrounded by ancient oak trees. Last fall our renters complained about rodents in the toilets. After a plumber ran a lighted instrument down the drain into the pipes, he discovered cracks that are allowing the rodents to enter. He could actually see them darting around!! He says we will have to rip out the parking area, remove the trees, and replace all the pipes - to the cost of $10,000 starting, with no guarantees about the upward costs! Please, is there anything else we can do? I think we saw a TOH show on running some sort of sleeve into the plumbing that repaired the crack without replacing everything. HELP!!!!
    7,762
    Default Re: Cracked plumbing
    What you saw on the show is called trenchless sewer line. It could be an option for you, depending on your existing line. Something that is unknown here: will the rodents chew the trenchless line?
    I prefer the old fashioned way of replacing the clay, cast iron or copper sewer line with black ABS - as your plumber probably suggested. Roots can't penetrate it, nor rodents.
    The cost? shop around. One estimate is not enough.
    The digging must be done professionally and safely. Learn about it beforehand, by asking questions at your building dept.
    May 2013
    The problem we ran into with getting estimates is that it requires the lighted probe thingy (whatever it is) to assess the problem. We could only find one person with the equipment. We feel trapped .... like "rodents."
    7,762
    Quote Originally Posted by Betsy Hester View Post
    That "thing" is called sewer camera/video. But once you had this done, you don't need it again - you already know what you have in your line.
    Just call other plumbers and ask them for estimate to replace your complete main line.
    7,762
    And another thing: many plumbers don't have this camera, they just sub the job to a guy with a camera.
    In any case, now you don't it inspected anymore.
    May 2013
    Thanks for the feedback ... one more thing ... Super glue won't work, huh?
    7,762
    I like your sense of humor. It will help you through this.
    Super glue might work but you will need a boat load, which will cost more than new pipes
    However there is a silver lining here: all work will be deductable, or the cost could be spread over a few years if it exceeds the total annual rent income, since it's a rental house (check with your tax adviser).
    1,890
    Make sure you get an itemized estimate. The plumber you already contacted may have factored excavation, landscaping, and concrete repair into the estimate. You may find it less expensive to be your own general contractor, and hire the excavator, plumber, concrete crew, and landscaper separately.
    May 2013
    Fairfax, VA
    37
    Sounds to me like you have quite the rodent problem. The sewer video could be helpful to other contractors if you want to get more than one estimate. See if a company will do the estimate for free. Our company offers that service, unsure if some in your area do but definitely worth asking about. Also, you may want to see if the original company is willing to let you have the video for a fee. That way you can comfortably shop around opinions and estimates.
    Hope that helps.
    Retroloco-LJ
    http://fhfurr.com
    Don't kill the dream, execute it.
    Retroloco-LJ
    Hidden Content
