    Oct 2012
    Houston, TX
    318
    Default floating a closet floor
    I am installing a cedar t&g floor over plywood in a small, 28x21 closet.
    Flooring is standard thickness, but will not be nailed because I just don't really see the need.
    Do I still need to use a vapor barrier over the plywood despite the small space?
    Also, should I glue the boards together?
    There is a bit of ventilation since the door was cut in the past to accommodate carpeted flooring.
    It's this old house, not this built after your dad was born house.
    8,065
    Default Re: floating a closet floor
    I would recommend the vapor barrier. As for fastening and gluing, you can probably get away with one or the other, you won't need both. Because it is a closet, who cares if it moves around a bit, you just don't want the joints separating (aesthetics only ). I would either glue the joints or throw a tack in them.
    If you start in the back of the closet, face the tongue towards the door and drive your tacks at an angle through the tongue. Tap your next board in place and repeat. When you get to the door, custom cut your final piece and surface tack it along the leading edge, making sure that the nails will be hidden by the transition strip you'll be installing.
