Results 1 to 10 of 11
    Apr 2013
    Default Question about a Leaning House
    Hello All,
    New to the forum, but looks like a good source of commentary so I figured I'd pose the question to you all.
    I just recently moved into a new house with a couple people (renting - not owning) and noticed that the house is leaning. The house is probably about 100 years old. Its a little dizzying inside - which isn't a big deal to me - but I'm concerned about it from a safety stand point. From my understanding, most of the settling in a house occurs within the first few years of its existence and that any lean has probably been that way for a long time.
    I just want to make sure that this is not a safety hazard to us living in the house. My biggest concern is the front right corner of the house. It seams to bend inward from the second floor level to the foundation and I worry about the stability of this corner of the house. There are no big visible cracks in the plaster, but the house sounds awfully creaky and there is slight visible sagging in the floor joists. Based on the floor depth, the joists are 2x8s at 24" O.C. and span the width of the house, which is about 13 feet.
    Thoughts? Does anyone else have experience living in a house with this condition?
    Any input is much appreciated. Thanks!
    821
    Default Re: Question about a Leaning House
    i've seen many many houses that are that old and older. some are level and plumb and some are scary crooked. sometimes the level and plumb ones can be a danger to be in and sometimes the crooked ones are perfectly safe. it goes both ways. there's no way anyone on here can tell you if it's safe or not. the only person that can help you out is to have a structural engineer come in and do an assessment. it might be perfectly fine, a danger or somewhere in between.
    5,558
    I agree with MLB but from your description " It seams to bend inward from the second floor level to the foundation" sounds like there may be a seriously compromised sill. This needs to be checked out.
    69
    I agree with the others that the building may or may not be unsafe---but under local law it's the responsibility of the town/city building inspector to accept complaints of this nature and to check them out using the town's structural/civil engineer; if a hazardous condition is found, the property owner is notified to have it fixed.
    Apr 2013
    Thanks for the input. Do you all consider it poor etiquette to consult the engineer without telling the owner first?
    821
    go right ahead and get one if you want to. don't worry about the landlord. this is about your safety, not his.
    1,381
    There are two conditions that could be at work here, settling and racking. If it was just settling, the floor would slant the same amount as the wall leans, but if the floor is level and the wall leans, that is racking and that is an even bigger concern.
    You might want to discuss this with the landlord, but I would not tell him or her that you may go to the city inspector. If you tell them that, things tend to get ugly.
    1,101
    Don't tell the government, at least not yet. If they assess the situation as dangerous and condemn it, you will not be allowed to go back inside for anything so you will lose all your belongings. Maybe the landlord will be nice and care enough to fix it, maybe not. If it worried me I'd just move ASAP then inform the government afterward. You can't really force the issue without risking some kind of loss yourself, and since you don't own the house there's no point in risking any loss when you don't have to. CYOA first, then protect others from potential harm.
    2,363
    As the others have said I'd get a good contractor in there to take a look around and figure out what has happened to the building over the last century. It may take a few sets of eyes to figure it out. Look up past residents and neighbors who may know.
    1,361
    If there has been any remodeling since the house settled, it may be nearly impossible to fix without first undoing that remodeling.
    Houses -- especially old ones -- do settle over time. Newer houses are less likely to settle because of the way modern building codes specify the installation of the foundation. By remodeling without first releveling, you end up with new stuff that's level and old stuff that's not level... if you level out the old stuff the new stuff won't be level anymore.
