can you extend the "red" to go up under the siding? That would be best.
Oh, yes definitely. I will cut the siding to lap down over the "red" and a bit onto the yellow. In theory (and if I had wrap), the wrap would go atop the "red" and create a water barrier to the sheathing. I'm just concerned that when I put the siding back on (masonite), that if water ever gets between the siding and sheathing, and gets locked-in somehow I'll have a serious rot issue. I've seen it on other parts of the house. I have two rows of the siding off now. One will go back on.
Below the ledger, I guess I'm hoping that the membrane will be sufficient as there is not much area to cover. So below the ledger there will just be the membrane atop the OSB.
