Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    May 2013
    Fairfax, VA
    37
    Default Re: Washing Machine Overflow Pan Drain Connection
    Could the problem lie in the hose and not in the washer? I know that sometimes rubber hoses don't offer enough "give". Just a suggestion - try stainless steel hose and see if that helps your situation at all.
    Best of luck.
    ~Retroloco-LJ
  2. #12
    1,884
    You might try a "bulkhead fitting." Available from many farm supply stores, as they are often used for stock watering tanks.
