    Apr 2013
    Default Forgot to caulk when installing window
    Please help. I installed a new window for my patio, but I forgot to apply caulk to the inside of the flange. I've already nailed the flange to the window frame with 2" roofing nails for every holes there is on the flange. What should I do now?
    1,002
    Default Re: Forgot to caulk when installing window
    cut (4) 6 inch strips of ice and water shield. 1st, one across the bottom, 2nd, one on each side, 3rd, one across the top. start against the window to cover the nail flange and spread it out onto the tyvek which should be on top of the sheathing.
    Sep 2009
    florida
    598
    Gizmo
    Hidden Content
    Hidden Content
    Apr 2013
    13
    A nail in every hole? *** really didnt want that window to go anywhere haha. yep as the two others have said just use some of the water seal tape and you should be fine applied bottom to top.
    Apr 2013
    Thank you so much for your help!
