Thread: Pipes gurgling
    Apr 2013
    Default Pipes gurgling
    We have a 2 story home with a septic tank. All piping connects into one that feeds into the tank. The kitchen sink is between the washer and the connection going to the tank. When the washing machine drains, I hear gurgling in the kitchen sink. If water is in the sink, the air will push the stopper out. This does not happen when you use any 3 of the bathrooms that are on the opposite side of the house from the washer. The washer cast iron drain pipe has been cleaned several times over the past 20 years for build up. There is no water backing up anywhere - just the gurgling sound.
    I have tried the baking soda and vinegar down the kitchen sink several times. I would try doing it to the washer pipe but that's a lot of soda and vinegar! Any suggestions?
    South*East
    1,213
    Default Re: Pipes gurgling
    You have a parcel stoppage in the line, it needs to be snaked.
    John
    Sep 2012
    Boston
    1,004
    look at the vent sticking through the roof and see if there's anything blocking it
    6,598
    This topic has come up a lot, so do some search and read some of the previous answers and suggestions.
