    Apr 2013
    Default adding second toilet to 3 inch drain
    I would like to add a second toilet, in a new bathroom, on the back side of our main second floor bathroom. The main bath toilet currently drains into a 3 inch pvc pipe. Can I simply add the second toilet down the line from the main bath toilet? Understanding, of course that the venting would have to be proper. I read somewhere, that, if you are adding a second toilet you have to increase the size of the drain from that toilet on.
    South*East
    1,257
    Default Re: adding second toilet to 3 inch drain
    3" is OK for two toilets.
    John
    1,901
    When I was plumbing 15 years ago, you could install up to three toilets on a 3" drain.
    South*East
    1,257
    You're correct but before the low flush toilets you were only allowed two toilets on 3".
    John
    Apr 2013
    Does it matter that there will also be a sink, tub and shower on the same line?
