    Apr 2013
    Default Window box installation
    The house we recently moved into has two wooden beams protruding through the exterior of the home below a 2nd floor window. I assume those are for a window box. Is it okay to just install a window box and attach it directly to the supports below the box or do I need to also find a way to attach the back side of the box to the house?
    Default Re: Window box installation
    The answer to your question will be a question or three:
    - do you mean a box for plants/flowers?
    - what size box are you planning and what is the weight going to be.
    - how stable are the two beam extensions?
