    Apr 2013
    Default Using T1-11 as lead abatement
    Hi to this discussion board. Although I'm new here, I've been flamed on other forums for years...mainly car restoration related. So here goes:
    I am rehabbing my first investment property, which is a 1912 small Victorian in Richmond Ca. Since the neighborhood isn't very nice, and I'm trying to keep costs low, I've been looking for some creative ways to rehab certain sticky spots on the house.
    First issue: lead paint abatement on exterior siding. The front and visible side of the house was already stripped when I bought the house, so refinishing the redwood V-rustic was a no brainer. The back and side of the house that isn't visible from the street has a ton of lead paint starting to flake off. My decision here is to try and cover the siding so I don't have to deal with costly lead abatement, etc., which could be 10K+ by someone licensed.
    My neighbor, who is a laborer with stucco experience, quoted me $3000 plus materials to stucco over the existing siding on those two sides of the house. The side wall is 48' x 14', with 3 small windows. It is just 4 feet away from the wall of the house next door. The back wall is 24' x 14', with lots of windows. So about $4k to stucco the two sides, and be done with the lead paint. This is no doubt a steal of a deal, but what if his stucco work is subpar, and the stucco wall starts coming off in a few years?
    I am considering T1-11 instead of the stucco, which I could do myself for around $1200 in wood panels. I already have the scaffolding at the house. My thought, though, was to hang the siding horizontally in order to try and pseudo-match the look of the 2 visible sides of the house. I know that this siding is not meant to be hung horizontally, since the butt ends would then run vertically, allowing a considerable gap for rain to get in, and because the grooves would then hold water since they run horizontally.
    How doable is this plan, since the siding underneath is already exposed to the weather? I would start with primed T1-11, would seal all edges, caulk the butt ends, etc. I would bevel the bottom edge of the grooves, and prime/caulk them so rain wouldn't sit in the grooves. I'm not looking for something to last another 100 years...if I can get 10 years of rental out of this house, I'd then consider putting in more money down the line to make a better restoration, but at this point, I'm trying to get the house up and rented (safely) with a minimum investment. For what its worth, the side wall gets no weather since it is so close to the other house...and the back wall gets little weather. Also...this is the Bay Area of California...and we don't get much weather other than sun most of the time.
    This is a $75K house that I am earmarking about 15K to rehab. No sense in putting in 10K+ just to return 2 sides of the house to original/lead free.
    7,343
    Default Re: Using T1-11 as lead abatement
    You have to investigate your options a little more carefully,, including getting more valid bids in writing. Then weigh all your options to decide what to do next.
    You are dealing with other factors as well, some are even beyond your control:
    1. Your location and neighborhood.
    2. The homes around you, which you mentioned as having low market value.
    3. Your ultimate goal: stay in the house or flip it.
    4. Your funds and your willingness to invest in such a property.
    Covering the invisible sides with T1-11 seems to be a reasonable way to go, IMHO.
    Apr 2013
    Hi,
    Thanks for the reply. I have considered other factors, and in general, for the neighborhood and comps, this house is a steal of a deal at my purchase price. It was never listed MLS, and in our current market, houses in the depressed neighborhoods of Oakland and Richmond are getting 10-20 bids, and selling for 25% over asking price.
    It will be a rental, so I want all of the lead paint securely covered. I generally am not paying anyone to do anything on this house, so there's really no reason for any other bids. I did research all of the EPA lead abatement practices, and the field guide that they publish, and have been working safely.
    We just had a rain, and the large side of the house didn't have a drop of water on it, so I think that these two walls get very little weather. We live close to the ocean, so the wind patterns are pretty consistent. I think the T1-11 is going to work fine for the purposes and considerations of this house.
    Thanks again...back to work!
