Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Tennessee
    2,015
    Default Re: wiring outlets in a chain
    I think that jumpering is OK between the duplexes in the quads, but pigtails to the first duplex in the quad. And you can jumper bottom to bottom if you want instead of bottom to top.
  2. #12
    Mar 2010
    Canada
    86
    Quote Originally Posted by toh409 View Post
    thanks for all the great replies i learned a lot.
    one other method i forgot to include for a "quad" is to feed from the top of outlet #1 jump from the bottom of # 1 to the bottom of #2 and feed out to the next on the line from the top of outlet #2. will this method also be acceptable?
    assuming all the outlets are for convenience and will not all be used simultaneously for heavy load item whats the max number you would feel comfortable running on a chain?
    also i have been advised by others that the practice of wrapping electrical tape around the wire nuts is amateur and should be avoided. i will have to guess that the same opinion holds true for wrapping the tape around the side of the outlets?
    thanks
    It may be amateur , but it doesn't hurt at all to do it.
    I have a master electrician that still uses tape on wire nuts and receptacles after almost 40 years in the profession.
  3. #13
    Columbiana, Alabama
    843
    Quote Originally Posted by LeonardHomes View Post
    It's suggested if the wire nut is a little small and allows some copper to show.
    Wrapping a receptacle is sometimes done to prevent a screw from touching the wall of a metal box. Also, be sure to tighten un-used receptacle screws to prevent this.
    Tape is used in many industrial applications, especially where vibration is present.
  4. #14
    6,047
    Extra safety is never amateurish.
  5. #15
    Nov 2012
    central pa
    98
    taping the outlet isnt amaturish i know quite a few electricians who do it it is not required by code anywhere as far as i know. but many electricians do it anyway especially in switch boxes with multiple switches that way down the road when you need to work on one switch you can do so without worring about touching the other ones. and i agree always tighten the unused screws i know that is code here in pa
  6. #16
    Columbiana, Alabama
    843
    Quote Originally Posted by junkout View Post
    Where in PA are you? The UL White Book allows stranded wire on almost all devices (switches and receptacles) from #14 to #10, as well as solid.
    Also, I've learned (the hard way) it's wise to tighten the screws out of the way but didn't know of any jurisdiction who required it.
  7. #17
    Nov 2012
    central pa
    98
    central pa i looked it up strand wire is ok and tightening the screw is a local code in one of the counties i work in i think there was a fire caused by a short to the box there.
  8. #18
    Columbiana, Alabama
    843
    good amendment
