    Mar 2013
    Default Portable A/C with one or two hoses
    A portable A/C unit with one hose uses some of the cooled air from inside the house and vents it outside to cool the condenser. Warm air from outside will be "sucked" in through cracks in the house. This creates a thermal inefficiency.
    A two hose system (if I understand correctly) uses one hose to bring the air into the unit for cooling the condenser only. The air then exits through the other hose. None of the cooled air from inside the house is being pushed out. In other words, the air that the 1 hose system "sucked" in through cracks in the house is pulled in through a hose and completley separated from the inside air of the house. This makes this two hose system thermally more efficient and cheaper to run.
    My question is though, how much of a difference does this make?
    I have a need to cool down one room in my house that is always hot in summer. When the other living space is at a comfortable level, this room is hot. The windows in this room are crank style windows, so I cannot use a window air conditioner or put hoses through the window. I will have to cut holes through the wall.
    Should I go with a two hose portable A/C unit which would require cutting two holes through the wall or is a one hose unit "good enough", saving me from cutting two holes through my house?
    Thanks for any replies.
    6,080
    Default Re: Portable A/C with one or two hoses
    I would consider a split AC unit.
    Feb 2013
    The thumb, MI
    54
    Yes that would be the best solution--but of course way too expensive to cool just one room.
    Before I would cut holes in the wall I would look into building a wedge-shaped panel that could be held in the window opening.
    2 vs. 1 hose...I think in practice there isn't much difference in efficiency between the 2. The 2-hose sounds like the right approach but remember it will always be drawing in hot outside air to cool the condenser, while the 1-hose unit is blowing cool conditioned air across it. Nevertheless I bought a 2-hose unit. It's fine for single-room use but it's not much help on larger spaces. A regular cheap window unit is far more effective than any portable.
    IF you really dont mind cutting your wall how about installing a window unit in the wall?
