    Mar 2013
    Default How to pressurize water coming from a cistern
    My parents have a cistern, they have a well and pump the water to the cistern and gravity flo to the house which makes it extremely low pressure. What is the most efficient way to pressurize the water? Can we buy a pump that would pressurize it directly from the cistern? Do we need a pressure tank? I have little knowledge about plumbing so your help is appreciated. Thank-You
    6,017
    Default Re: How to pressurize water coming from a cistern
    You should be able to install a shallow well pump fed by the cistern, and yes you will need a pressure tank along with a check valve.
    Mar 2013
    London
    You could use a booster pump, get an universal one for use in both Positive and Negative Head Systems
    Feb 2012
    92
    Booster pump is the easiest most cost effective way,
    Ben Franklin Plumbing
    372 D St
    Salt Lake City, UT 84104
    (801) 416-3522
    http://www.benfranklinplumbingut.com/salt-lake-city-ut/
    Apr 2013
    Try a Davey Booster Pump they are quite and can pressurize 38psi, 50psi, 58psi, 76psi over incoming house pressure with flows up to 25gpm and you don't need a tank, go to boosterboys.com
