Results 1 to 10 of 14
    Oct 2008
    20
    Default Buff haze out of hardwood flooring?
    I placed a small area rug down without a pad on my hardwood floor and now there is an area that looks like its been rubbed with really fine sandpaper. There is no deep scratches or gouges, the finish just looks hazy.
    Is there a product I can use to buff this area out? Can I do it by hand if its a small area?
    BTW, my flooring is has a semi gloss finish NOT high gloss.
    Sep 2012
    Boston
    1,002
    Default Re: Buff haze out of hardwood flooring?
    what i would do is to lightly sand the area under the rug and feather the sanding into the unharmed part of the floor. then repoly with some semi gloss. you can't bring back the shine with buffing, the gloss finish has been worn away.
    Oct 2008
    20
    What about a wax like product? It works on cars
    Sep 2012
    Boston
    1,002
    but it won't last, you'll have to keep redoing it weekly or monthly
    Oct 2008
    20
    Its a very low traffic area.
    Anyone else have any ideas?
    Nov 2012
    14
    I have tried several things and spent hours on my hands and knees, until I used Windex which seems to have worked fine. It took all the haze off and my floors look great.
    Sep 2012
    Boston
    1,002
    it's really a very simple process and it shouldn't take you more than a half hour. when you're done the floor will look just like the rest of your floors and the finish will last. why cut corners for a half hour of labor and $10 in materials.
    Oct 2008
    20
    Quote Originally Posted by MLB Construction View Post
    The room is going to be used for a newborn baby. The offgassing of the poly is not an option.
    Typically, I don't cut corners... this time I have to.
    1,386
    Try rubbing out the dull area with a Magic Eraser. It works like a buffing compound but since there is no wax it won't make the floor slippery.
    Casey
    Oct 2008
    20
    These are the kind of MacGyver solutions I'm looking for.
    That said... rather than using something "like a buffing compound"... is there an actual buffing compound I could apply by hand?
