    Mar 2013
    Default Sewer Drain Stopper? Product seen on This Old House
    Hi everybody,
    I am looking for this product- it was seen on This Old House a while ago. I am not sure on the correct name.
    But it is a sewer drain stop- doesn’t allow the water from the sewer to enter the basement (because of a ball that rises with the water level). Can you help me to find this product?
    Sincerely,
    Basket Case
    6,527
    Default Re: Sewer Drain Stopper? Product seen on This Old House
    Do you mean a "back flow preventer"?
    WATTS makes them, as well as others.
    Feb 2012
    92
    I believe what you are looking for is called a backwater valve and they come in many different styled one is a ball like you described one is a flapper which isn't very good because a lot of the time stuff gets stuck in the hatch then they have this other type which I believe the last one I installed was similar to this http://www.backwater-valves.com/ hope this helps you find what you are looking for, It is not a back flow by watt's that is just to prevent siphoning from like drink machines, etc... mixing into your drinking water.
    Ben Franklin Plumbing
    372 D St
    Salt Lake City, UT 84104
    (801) 416-3522
    http://www.benfranklinplumbingut.com/salt-lake-city-ut/
