    Mar 2013
    24
    Default good "repair mortar" recommendations
    any recommendations for a good general purpose REPAIR MORTAR
    for holes in floors, walls,cracked step and wall corners etc.
    i tried basic sakrete mortar but realize this is basically useless for other than laying brick and block. the floor repairs i did with it in my basement turn into a dusty surface.
    i know MAPEI makes a full line of products but there must be others as well?
    thanks
    Jun 2009
    393
    Default Re: good "repair mortar" recommendations
    For walls check this site and select the correct repair mortar for your wall types.
    www.mc2
    Under Services select Estimator's Ref.
    Than select Mortars.
    select the one that fits your requirements.
    Floors and Steps use a high PSI cement.
